hoser7632's avatar
hoser7632
Follower
Jan 28, 2026
Help understanding the "Set the 802.1Q VLAN and management VLAN" WBE750
On my router I have a X550 interface tagged with a vlan ID of "4" which attaches to my switch port as a "trunk port with a vlan id of "4"" on the switch I have an "access Port with a vlan id of "4" that is connected to my "WBE750" RJ45.
In the LAN settings of the WBE750 Do I place the vlan id of 4 in the "Untagged VLAN" setting or the "Managed VLAN" setting.
Any assistance would be greatly appreciated.
Best Regards
  • StephenB's avatar
    Not sure what you are trying to achieve.  Is all the traffic running through the AP on VLAN 4?
    Assuming yes:  Access ports are not tagged - the router and switches will add the tags when sending packets on the trunks.  So I don't think you need to configure the VLAN on the AP at all.
    If no:  Then the router switch port going to the AP should be a trunk.  The VLAN settings on both the router and the AP depend on the details of what you are wanting to achieve.
  • schumaku's avatar
    schumaku
    Is this X550 a router product name (in this case please provide details like product manufacturer, exact model, and firmware version in place) or are you talking of the WBE750?
    Before wasting any time: Does your router have some VLAN support, or at least a separated Ethernet port connecting to a different network, IP subnet (or VLAN)?
  • schumaku's avatar
    schumaku
    You can operate the management VLAN and each SSID on dedicated (tagged!) VLAN(s) - of course these VLANs must exist,  be have to be workable, need dedicated IP subnetwork(s), and ideally each a DHCP service active. An access port alone  is not sufficient, as this makes untagged traffic for one VLAN only.
  • schumaku's avatar
    schumaku
    This in the context with the SSID - the VLAN you want devices associated to this WLAN will be assigned to.
    hoser7632 wrote:
    In the LAN settings of the WBE750 Do I place the vlan id of 4 ...  or the "Managed VLAN" setting.
    This is in the context of the AP administration - this is management VLAN you intend to use.
    In each case, these are both dot1q [T]agged VLANs. Simple enough?
ProSupport for Business
