hoser7632
Jan 28, 2026Follower
Help understanding the "Set the 802.1Q VLAN and management VLAN" WBE750
On my router I have a X550 interface tagged with a vlan ID of "4" which attaches to my switch port as a "trunk port with a vlan id of "4"" on the switch I have an "access Port with a vlan id of "4" t...
schumaku
Mar 14, 2026Guru - Experienced User
hoser7632 wrote:In the LAN settings of the WBE750 Do I place the vlan id of 4 in the "Untagged VLAN" setting
This in the context with the SSID - the VLAN you want devices associated to this WLAN will be assigned to.
hoser7632 wrote:In the LAN settings of the WBE750 Do I place the vlan id of 4 ... or the "Managed VLAN" setting.
This is in the context of the AP administration - this is management VLAN you intend to use.
In each case, these are both dot1q [T]agged VLANs. Simple enough?
