macounwr
Aug 25, 2015Tutor
Using a CA SSL Certificate (from NameCheap) to enable SSL VPN
I am trying to enable SSL VPN on FVS336G. I have taken the trouble to obtain a certificate, and I have registered a corresponding domain that resolves to the static IP address of my router.
I u...
JohnRo
Aug 26, 2015NETGEAR Employee Retired
Hello macounwr,
Can I get some information on your setup? I have listed my questions below:
1. Firmware version.
2. Certificate name/version/manufacturer.
3. Browser(s) used.
I'll look forward to your response.
Thanks,
- macounwrAug 26, 2015Tutor
Firmware 3.0.7-24
Here's a screenshot of my installed certificate:
https://www.dropbox.com/s/3eih8pceh7qk0mc/Screenshot%202015-08-26%2014.09.15.png?dl=0
Using IE on Windows 7. Reason I am pursuing this is I have a user who has upgraded (?) to Windows 10, and his IPSEC client no longer works.
Thanks for any help.
- JohnRoAug 27, 2015NETGEAR Employee Retired
Hello macounwr,
It is either you have a version 1 hardware of the FVS336G or the firmware you are using is way behind. The certificate you uploaded looks good to me, remove the VPN configuration and run it using the instructions on this link.
Hope this one helps, if you have more questions feel free to ask.
Thanks,
- macounwrAug 27, 2015Tutor
My router is a version 1, and the firmware I am running is the latest version available.
I clicked the link, but I was presented a login challenge, and it is apparently different than my login for this forum, so I was unable to get to it.
Can you please post the instructions here?
Thanks,
