gandmclark's avatar
May 02, 2018
OpenVPN No server certificate verification method has been enabled.
Hi,
I'm using a R7000 running V1.0.9.28_10.2.32.
I just enabled VPN and tried to connect via a Windows 10 OpenVPN client but get the following errors in the VPN Windows Log
I removed the normal messages at the start of the log but can provide them if required.
Wed May 02 17:00:46 2018 us=65248 WARNING: No server certificate verification method has been enabled.  See http://openvpn.net/howto.html#mitm for more info.
Wed May 02 17:00:46 2018 us=65248 OpenSSL: error:140AB18E:SSL routines:SSL_CTX_use_certificate:ca md too weak
Wed May 02 17:00:46 2018 us=65248 MANAGEMENT: Client disconnected
Wed May 02 17:00:46 2018 us=65248 Cannot load certificate file client.crt
Wed May 02 17:00:46 2018 us=65248 Exiting due to fatal error
This is using the downloaded configuration from my Netgear router's Advanced Setup VPN.
I use a static IP provided by my ISP so don't need to provide a a Dynamic DNS setting. I've modified the client1 config accordingly with my external static IP.
Looks to me as though the internal Netgear VPN Server's cert is somehow incorrect!
Any ideas?
  • You need to update you router to the latest one version 1.0.9.30 witch fixes a problem with OpenVPN.
    • gandmclark's avatar
      gandmclark
      Guide
      Thanks StephenCanada73,
      I have managed to fix the issue. I was using the very latest OpenVPN 2.4.6 when testing but rolling back to 2.3.18 fixed the problem.
      However you pointed me to the new R7000 firmware that may well work with the latest OpenVPN. I'll give that a try sometime soon.
      Thanks for that.
      • LA12's avatar
        LA12
        I have the same problem with my R7000 nighhawk AC1900 router. I installed the OPENVPN, updated the netgear firmware to 1.0.9.30 and I still have the same problem as yours. I am about to give up. Is there another way  to make it functional?
  • Similar issues...
    Recieving these errors after updating R7000 FW to V1.0.9.30_10.2.33:
    "WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info."
    After sitting for a minute, I recieve these errors:
    "TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)"
    "TLS Error: TLS handshake failed"
    I have tried resetting the router as well. Any help would be much appreciated.
    Edit:
    Windows 10 OS using most recent version of OpenVPN
    • shamarin's avatar
      shamarin
      Virtuoso
      Reupdate OpenVPN config to new one via routerlogin.net/openvpn_crt_check.htm. For me it was the same. Did an update several times without reseting and it's became normal. And also after an update reboot router.
