gandmclark
May 02, 2018Guide
OpenVPN No server certificate verification method has been enabled.
Hi,
I'm using a R7000 running V1.0.9.28_10.2.32.
I just enabled VPN and tried to connect via a Windows 10 OpenVPN client but get the following errors in the VPN Windows Log
I removed the no...
- May 02, 2018
You need to update you router to the latest one version 1.0.9.30 witch fixes a problem with OpenVPN.
shamarin
May 02, 2018Virtuoso
- gandmclarkMay 04, 2018Guide
Yes updating to the beta firmware fixed the issue.
- LA12May 22, 2018Aspirant
I have the same problem with my R7000 nighhawk AC1900 router. I installed the OPENVPN, updated the netgear firmware to 1.0.9.30 and I still have the same problem as yours. I am about to give up. Is there another way to make it functional?
