gandmclark
May 02, 2018Guide
OpenVPN No server certificate verification method has been enabled.
Hi,
I'm using a R7000 running V1.0.9.28_10.2.32.
I just enabled VPN and tried to connect via a Windows 10 OpenVPN client but get the following errors in the VPN Windows Log
I removed the no...
- May 02, 2018
You need to update you router to the latest one version 1.0.9.30 witch fixes a problem with OpenVPN.
ItsSmoker
Jun 03, 2018Aspirant
Similar issues...
Recieving these errors after updating R7000 FW to V1.0.9.30_10.2.33:
"WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info."
After sitting for a minute, I recieve these errors:
"TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)"
"TLS Error: TLS handshake failed"
I have tried resetting the router as well. Any help would be much appreciated.
Edit:
Windows 10 OS using most recent version of OpenVPN
- shamarinJun 04, 2018Virtuoso
Reupdate OpenVPN config to new one via routerlogin.net/openvpn_crt_check.htm. For me it was the same. Did an update several times without reseting and it's became normal. And also after an update reboot router.
