cisberg
Jul 27, 2015Aspirant
Virtual Passage Installation error - Windows 7 and Netgear FVS336Gv2 VPN Firewall
I have a Netgear FVS336Gv2 VPN Firewall with the firmware 4.3.3-5 installed but I can't get my Windows 7 Professional machines to connect properly. The Windows 7 machines are 64-bit and they can log...
- Jul 27, 2015
I still can't get into the Community site to view the link you sent, but I was able to access the PDF you made available through the app.box. I followed those instructions and now I am able to get the Virtual Passage installation to work. Thank you for the help!
cisberg
I tried clicking on the link but it says I don't have sufficient priviledges to access the information.
DaneA
Jul 27, 2015NETGEAR Employee Retired
Hi cisberg,
After clicking the link and its asking you to enter login credentials, kindly enter your e-mail and password that you use to sign in here in the newly launch Netgear Community so that you could access the link I have provided on my previous response.
DaneA
Netgear Community Team
- cisbergJul 27, 2015Aspirant
I tried again (closing out Chrome completely) and after entering my credentials I got the same "Access Denied" message.
Also, I just tried lauching the connection using IE 11 64-bit (instead of the default 32-bit) and I don't get the error message any more about adding the site to the Trusted Sites. However, the Virtual Passage installation still fails after I click on the VPN tunnel link.
- DaneAJul 27, 2015NETGEAR Employee Retired
Hi cisberg,
Were you able to access the link I have provided? Its because I can access it just fine on a different PC just by signing in to the new Netgear community.
Kindly try the following steps below:
1. Close IE11 64-bit
2. Download and install Microsoft Visual C++ 2005 and Visual C++ 2008. Here are the links below respectively:
http://www.microsoft.com/en-us/download/details.aspx?id=18471
http://www.microsoft.com/en-us/download/details.aspx?id=10015
3. Open IE11 64-bit
4. Added the portal to "Trusted Sites."
5. Tried to login to the Portal.Note: If ever the above steps does not work, try to reboot your PC and try to login to the portal again.
DaneA
