Gorden
Oct 13, 2017Aspirant
vita 49 packet issue
I have several SRXN3205 routers, all with 3.1.1-08 firmware, at several locations operating with different ISP's. When trying to connect a remote client radio device to any of those routers and conn...
DaneA
Oct 15, 2017NETGEAR Employee Retired
Hi Gorden,
As far as I have checked, there are no issues logged for the SRXN3205 about the issue as per you have described on your initial post.
I searched online about Vita 49 packets and found this link. Let us try this, since there is a remote client radio device connecting from outside the network, kindly open TCP/UDP ports 4991 and 4992 on the SRXN3205 and point it to the LAN IP Address of the server radio device. Then, check if same problem occurs.
If ever opening TCP/UDP ports 4991 and 4992 on the SRXN3205 does not help, kindly try to open all ports and see if that would allow the remote client radio device connect from outside the network.
Let us know the result.
DaneA
NETGEAR Community Team
