Gorden
Oct 13, 2017Aspirant
vita 49 packet issue
I have several SRXN3205 routers, all with 3.1.1-08 firmware, at several locations operating with different ISP's. When trying to connect a remote client radio device to any of those routers and conn...
Gorden
Oct 24, 2017Aspirant
Sorry for the delay in responding. Yes we did try your suggestions. That did not fix it.
Alternatively I went on Amazon and bought a FVG318 router to test. Without any port forwarding settings it provides client access to the radio which we can't get though to using several different SRXN3205 routers. The required port settings are for the server end of the connection. No special port settings are need for the client. The client is suppose to use most any network connection and for the most part it does but not the 3205 routers. They are not passing vita 49 packets.
This needs to get fixed.
DaneA
Nov 07, 2017NETGEAR Employee Retired
I apologize for the late response. I understand that port forwarding is not needed on other firewalls (such as the FVG318) to let vita 49 packets to pass through which is why I inquired your concern to the higher tier of NETGEAR Support.
I'm afraid to inform you that as per the the higher tier of NETGEAR Support, since the SRNX3205 is already End-of-Life (EOL), it won't be getting any new firmware releases to address the problem of not allowing vita 49 packets to pass.
DaneA
NETGEAR Community Team
