bpoe138
Nov 22, 2020Initiate
VLAN routing on BR200
I'm trying to setup a Guest wifi network. I have a BR200 router, GS316PP unmanaged POE+ switch and a WAX610 WAP. I have the Default VLAN 1 (10.0.1.0/24). I tried to create a new VLAN 8 (10.0.8.0/...
Jeff4021
Nov 22, 2020Aspirant
This really refers to the BR200, but I am also having a very similar problem. I have a BR200 and then an Orbi Rbr200 with one satellite. The RBR is for a guest network, and is on AP mode. I am also able to get as far as getting an IP from the VLAN DHCP, but can’t get internet access. Feels like some sort of DNS type situation, like even though the DHCP is setup right, it can’t resolve internet IPs. If I run an ipconfig/all on a VLAN connected device (vlan 3 because the br200 has management and video vlans built in using ids 1 and 2). I’m using 10.1.1.1/24 as the primary network 10.1.2.1/24 for the wireless trunk.
- DaneAJan 14, 2021NETGEAR Employee Retired
Welcome to the community! :)
I inquired you concern to the higher tier of NETGEAR Support. Kindly check the document attached on how to configure inter-VLAN routing on BR200 / BR500 using its web-GUI and use it as your guide.
DaneA
NETGEAR Community Team
- bpoe138Jan 14, 2021InitiateI returned the device and I am now using a Ubiquity EdgeRouter4. I was easily able to setup inter-VLAN routing on it using the CLI.
