bpoe138
Nov 22, 2020Initiate
VLAN routing on BR200
I'm trying to setup a Guest wifi network. I have a BR200 router, GS316PP unmanaged POE+ switch and a WAX610 WAP. I have the Default VLAN 1 (10.0.1.0/24). I tried to create a new VLAN 8 (10.0.8.0/...
DaneA
Jan 14, 2021NETGEAR Employee Retired
Welcome to the community! :)
I inquired you concern to the higher tier of NETGEAR Support. Kindly check the document attached on how to configure inter-VLAN routing on BR200 / BR500 using its web-GUI and use it as your guide.
DaneA
NETGEAR Community Team
bpoe138
Jan 14, 2021Initiate
I returned the device and I am now using a Ubiquity EdgeRouter4. I was easily able to setup inter-VLAN routing on it using the CLI.
