gimnicher
Dec 21, 2016Aspirant
VPN Client license key lost for SRX5308
I purchased the firewall in October of 2015 and am just now wanting to use the VPN features. Unfortunately, I cannot locate the original CD containing the license key required to activate the five V...
- Dec 21, 2016
Hi gimnicher,
That, I'm not sure. As it was not indicated on the key information, usually lite licenses are single. The best way to know is to install it and use the license. There was a "5U" code on the license code, so there's a chance it a 5-user license.
Thanks,
gimnicher
Thank you so much for doing this. One final question: is the lite license key you sent me good for the original 5 copies or just for 1 copy?
JohnRo
Dec 21, 2016NETGEAR Employee Retired
Hi gimnicher,
Thanks,
