SYSguy
Aug 31, 2020Aspirant
VPN Client Pro - License Reset Please
I have a VPN Client that suddently had it's license deactivated. It is one member of a 5-pack and has been operational for years. Now when I try to reactivate I get the error "license already in use"...
- Aug 31, 2020
I got your private message and sent a request to reset your VPN license key. As an update, I got a feedback that one of the 5-user VPN license key has been reset as per the e-mail address you have provided. You may register again the VPN license key.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
DaneA
Aug 31, 2020NETGEAR Employee Retired
Welcome to the community! :)
Kindly send me the following below via private message:
a. The VPN license key that needs to be reset
b. E-mail address/es that was used when you have registered the 5-user VPN license key
DaneA
DaneA
DaneA
