Jamespiclbiz
Jan 07, 2019Initiate
Vpn licence reset - Netgear Vpn Client Professional
I need to have my vpn licence reset after i changed PCs - any ideas on how this can be acheived please?
- Jan 08, 2019
Hi Jamespiclbiz,
I got your private message and I glad to inform you that your VPN license key has been reset. You can now register it again on your new PC.
Since your concern has been addressed and if ever you do not have further concerns, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
DaneA
Jan 08, 2019NETGEAR Employee Retired
Hi Jamespiclbiz,
Welcome to the community! :)
Kindly send me the following below via private message:
a. the VPN license key that needs to be reset
b. e-mail address that was used when you have registered the VPN license key
DaneA
- DaneAJan 08, 2019NETGEAR Employee Retired
Hi Jamespiclbiz,
Regards,DaneA
- JamespiclbizJan 08, 2019Initiate
Many thanks
James
