reading_na's avatar
reading_na
Follower
Feb 02, 2020
Help with Netgear ProSafe VPN Client Professional Software Licence Key Reset
Good afternoon,
I have just lost my licence key for my copy of Netgear ProSafe VPN Client Professional Software.  Is there away of getting the central registery update indor that I can reactivate my licence.  I am getting the rror message that the licence key is alrwady in use.
If I have used the wrong Discussion Thread would you be so kind an poinyt me in right direction.
Thanking you in advance for youe help with this matter.
Kind regards
  • reading_na,
    Welcome to the community! :)
    Were you able to check the CD sleeve of the CD installer of the NETGEAR VPN Client Professional software?  If not yet, kindly check it.  Otherwise, kindly send me via private message the e-mail address that you used when you have registered the VPN license key before.
    DaneA
    NETGEAR Community Team
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    reading_na,
    DaneA
ProSupport for Business
