Razorudy
Dec 21, 2020Follower
Download software for Netgear Nighthawk AC1900 USB 3.0, Dual Band
My desktop does not have a CD drive and I cannot use the disk that comes with the device. Is there a way I can download the information on the disk with a website. Could not find on the NETGEAR website.
- AC1900 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds. If you own the A7000 listed in your footer, then the best place to go to the section behind this link: - WiFi Adapters - NETGEAR Communities - You'll see that your question comes up every few days. - If you read the Quick Start guide that came with the adapter you will see that it says: - Note: If your computer does not include a CD drive, visit netgear.com/support
 to download the adapter software.
- > [...] Could not find on the NETGEAR website. - Visit http://netgear.com/support , put in your model number, and look
 for Downloads?- ChiggaAspirantc700|nighthawk-ac1900 usb cable modem router - > Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router - https://kb.netgear.com/000036375 - Is there some actual problem which you are trying to solve?
- michaelkenwardGuru - Experienced UserAC1900 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds. If you own the A7000 listed in your footer, then the best place to go to the section behind this link: WiFi Adapters - NETGEAR Communities You'll see that your question comes up every few days. If you read the Quick Start guide that came with the adapter you will see that it says: Note: If your computer does not include a CD drive, visit netgear.com/support
- ChiggaAspirantjkij
