Froese
Oct 19, 2016Aspirant
VPN no longer working between two FVS318Gv2
I have two FVS318Gv2 at two offices with a VPN tunnel between them that have worked fine until yesterday when the Internet provider was changed at one location. Broadband ISP settings were changed an...
- Nov 09, 2016
I finally had AT&T tech come out and replace the Pace 5268AC with a Motorola NVG589. Set it up as "pass-through" and now everything works fine. The tech said that his was a common problem for business customers using the Pace 5268. Apparently it just can't be made to pass VPN traffic.
Froese
Oct 23, 2016Aspirant
Thank you, but I have already delete and re-created VPN setting on both sides.
The issue seems to be with the AT&T supplied Pace 5268AC RG. Even though I've put the FVS318Gv2 in the RG's "DMZ+" and disabled everthing else that I could find, it still seems to be blocking GRE packets (although tunnel is set up.)
Dan_Z
Oct 24, 2016NETGEAR Expert
Hi Froese,
Thanks for your reply.
Could you tell me the internet connection mode,PPPOE,ADSL or other?
Thanks.
- FroeseOct 24, 2016Aspirant
It's ADSL (AT&T U-Verse).
Now I am experiencing other problems: long load times for certain website (sometimes they even time out, but work when re-tried.) Not sure if it's a DNS thing or related to this...which I am begininng to suspect now: something timeing out and resetablishing every couple of seconds (and it seems to affect all Internet traffic).
- Dan_ZOct 24, 2016NETGEAR Expert
Hi Froese,
Suggest you use DDNS.
Thanks.- FroeseOct 26, 2016Aspirant
Our WAN IP from AT&T is not static, but it has not changed since installation nearly 2 weeks ago, and I've read that other U-verse subscribers have reported that their IP didn't change for years, so I don't see why this would be necessay.
