dewdiehl
Jan 31, 2018Aspirant
VPN tp client light connetion failure SRX5308
Having trouble making a VPN client light connection. I've followed the online help pages and still no luck. Below is the log from the VPN Box. ERROR: Failed to get proposal for responder. Wed ...
DaneA
Feb 01, 2018NETGEAR Employee Retired
Hi dewdiehl,
I suggest you to delete the existing IKE and VPN policies in the SRX5308. Then, read the following articles below and use it as your guide in setting up client-to-box IPSec VPN:
ProSAFE VPN Client: Client to Box Configuration
Configure IPSec VPN Tunnels With the Wizard - read pages 8-15
Notes:
a. Make sure that the local IP address of the PC (where the VPN Client Lite software is installed) is on a different LAN subnet than what is indicated on the LAN subnet of SRX5308. For example, if the existing LAN subnet of the SRX5308 is on 192.168.1.x network, then the LAN IP address of the PC where you are using the VPN Client Lite software should be on a different LAN subnet such 10.10.10.x or 192.168.9.x network. As reference, check the image below:
b. You might need to disable the anti-virus or software firewall installed on the PC where the ProSAFE VPN Client Lite software is installed.
DaneA
NETGEAR Community Team
DaneA
Feb 04, 2018NETGEAR Employee Retired
I just want to follow-up on this. Were you able to try my suggestions and follow the notes? If yes, what is the result?
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
- dewdiehlFeb 05, 2018Aspirant
Hello. Yes I was able to get it working. Found that one of my other VPN connections was using the same ip address as the new connection I was trying to set up. Once I changed the DHCP scheme on the new connection all worked great.
Thanks again.
- DaneAFeb 05, 2018NETGEAR Employee Retired
Thanks for the feedback. I'm glad to know that you were able to get it working. :)
Since your concern is now resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution.
Cheers,
DaneA
