kmmcd
Nov 02, 2025Aspirant
Pending Drive Failure - Need Advice
I have an RN424 with three WD Red 6TB drives (WD60EFRX). A review of my log today indicates occasional "reallocated sector counts" and a recent single logged "ATA error count [14]." A popup indicated that I should prepare for a disk failure. To this end, I have some questions:
- Can the WD Red (WD60EFRX) be replaced with a WS Red Plus 6TB drive (WD60EFPX or WD60EFZX)? WD60EFRX Red drives seem to no longer be available. Also, the WD Red drives are SMS whereas the Plus drives are CMR. Does this matter?
- If the drive fails, do I just need to hot remove the failed drive and hot insert the new drive?
- About how long should I expect data recovery to take?
- Will my data still be accessible if and after the drive has failed, before I have installed a new replacement drive?
- Should I pre-emptively replace the "failing" drive before it actually fails?
thanks
kmmcd wrote:
ATA Error Count: 14
Reallocated Sectors: 569
Reallocation Events: 59Definitely needs replacement.
The WD60EFRX is CMR (not SMR), and you should only use CMR drives with ReadyNAS. WD rebranded their Red CMR drives as Red Plus some years back, but the WD60EFRX pre-dates that rebranding.
Red Plus are all CMR, so either the WD60EPRX or the WD60EFZX are ok. Avoid the WD60EFAX if you see it - it is SMR.
That is the procedure I normally recommend. That said, it is really important to remove the right drive, and things will go very wrong if you accidentally remove the wrong one and then reinsert it. So if there is any doubt about the slot then you should power down before removing, and then confirm the serial number. You can then insert the replacement with the NAS powered down.
Netgear does recommend making sure you have a backup before manipulating disks, and I agree with their advice. At least back up the irreplacable stuff (family photos/videos, documents) while you are waiting for the replacement to arrive.
Will my data still be accessible if and after the drive has failed, before I have installed a new replacement drive?If all goes as usual, then the data remains available through the entire process. The volume will change to a degraded status as soon as you remove the drive, and it will remain degraded until after you insert the replacement and the RAID resync finishes. The amount of time it takes depends in part on the size of your array, and in part on how much else the NAS is doing during the resync. I'd expect around 12-24 hours for a 4x6TB array.
Note that the volume is not protected when the array is degraded. So if another disk fails during the resync process, the volume will fail and you will lose your data.
It depends in part on how many errors you are seeing. You might want to download the log zip file, and look at disk_info.log and smart_history.log. Also you can look for errors in systemd-journal.log - that will show errors that are not in the other two logs.
But it also depends on your risk personal tolerance, and the consequence of data loss.
Personally I replace disks when the reallocated+pending sector count (combined) reaches around 20 or more. I have also replaced some disks that repeatedly throw other errors. Usually I am replacing them before the NAS says they've failed.
- kmmcdAspirant
Thanks for your thorough reply.
Is the WD60EFPX OK? I can have one of those here tomorrow.
The error log (excerpt attached) indicates the problem is with Disc 1.
However, I cannot correlate for sure which drive is #1. I assume that it is the one of the far left as I face the NAS with its front door open. Correct?
kmmcd wrote:
Is the WD60EFPX OK?
Yes. I said as that above.
Yes.
But, if you have any doubt, then download the log zip file and look at disk_info.log. That will show the smart stats and the serial number. That would also let you know if there are any other disks at risk.
Then you can use the power-down method I outlined above.
- kmmcdAspirant
- kmmcdAspirant
Thanks for your help. The new disk (WD60EPFX) arrives Thursday. I hope the existing one hangs on until then!
Device: sdc
Controller: 0
Channel: 0
Model: WDC WD60EFRX-68L0BN1
Serial: WD-WXJ1H26VUHTL
Firmware: 82.00A82W
Class: SATA
RPM: 5700
Sectors: 11721045168
Pool: data
PoolType: RAID 5
PoolState: 1
PoolHostId: a43725a
Health data
ATA Error Count: 14
Spin Retry Count: 0
Current Pending Sector Count: 0
Uncorrectable Sector Count: 0
Temperature: 42
Start/Stop Count: 18
Power-On Hours: 71035
Power Cycle Count: 18
Load Cycle Count: 126The error count and reallocation events on sda and sdc are 0.
kmmcd wrote:
ATA Error Count: 14
- kmmcdAspirant
I meant: The error count and reallocation events on sda and sdb are 0.
- kmmcdAspirant
I think that the drive has just failed. Its LED is out (slot 1, presumably), and I can't even access the admin page. My new drive arrives in a day or two.
Should I just power down the unit now and wait for the new drive? (I wonder whether it will respond to the power button, since I can't even access the web page.)
If I should power it down, and it will not respond to the button, should I just unplug it?
Or, should I just leave it up and running and let it do its thing?
Normally the system will keep running, but it is possible that the NAS is struggling to use it.
Since you are sure of the slot, it should be safe to just pull the drive and then see if the NAS becomes responsive again.
Then power down if it does not.
- kmmcdAspirant
UPDATE: Admin page is up, and I am able to access the drives again. There are warnings of additional errors detected. So, I am able to use the system as I type this, but I still have these questions:
Do you advice that I just power down the unit now and wait for the new drive?
- kmmcdAspirant
I replaced the drive following your powerdown procedure instructions, and the system is now back up. It took about 12 hours to resync. Thank you for your valuable help.
Great!
