kmmcd
Nov 02, 2025Aspirant
Pending Drive Failure - Need Advice
I have an RN424 with three WD Red 6TB drives (WD60EFRX). A review of my log today indicates occasional "reallocated sector counts" and a recent single logged "ATA error count [14]." A popup indicated...
- Nov 03, 2025
kmmcd wrote:
ATA Error Count: 14
Reallocated Sectors: 569
Reallocation Events: 59Definitely needs replacement.
kmmcd
Thanks for your thorough reply.
Is the WD60EFPX OK? I can have one of those here tomorrow.
The error log (excerpt attached) indicates the problem is with Disc 1.
However, I cannot correlate for sure which drive is #1. I assume that it is the one of the far left as I face the NAS with its front door open. Correct?
Nov 02, 2025Guru - Experienced User
kmmcd wrote:Is the WD60EFPX OK?
Yes. I said as that above.
kmmcd wrote:I assume that it is the one of the far left as I face the NAS with its front door open. Correct?
Yes.
But, if you have any doubt, then download the log zip file and look at disk_info.log. That will show the smart stats and the serial number. That would also let you know if there are any other disks at risk.
Then you can use the power-down method I outlined above.
