dewdiehl
Jan 31, 2018Aspirant
VPN tp client light connetion failure SRX5308
Having trouble making a VPN client light connection. I've followed the online help pages and still no luck. Below is the log from the VPN Box. ERROR: Failed to get proposal for responder. Wed ...
DaneA
Feb 04, 2018NETGEAR Employee Retired
I just want to follow-up on this. Were you able to try my suggestions and follow the notes? If yes, what is the result?
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
dewdiehl
Feb 05, 2018Aspirant
Hello. Yes I was able to get it working. Found that one of my other VPN connections was using the same ip address as the new connection I was trying to set up. Once I changed the DHCP scheme on the new connection all worked great.
Thanks again.
