genesearch
Feb 16, 2016Aspirant
VPN use Mode Config Record fails
The FVS336G is the gateway and the LAN uses 192.168.1.x IP range. I can create the IPSEC VPN, using VPN Policy as per the instruction manual, and it works great, and so easy to configure. All my ...
adit
Feb 16, 2016Mentor
If I remember correctly Mode Config did not work with IPSecuritas.
LAN1 192.168.1.0 to LAN2 192.168.1.0 will never work.
If you are concerned about common LAN subnets having an issue with yours then you will need to change it.
These are the one you should not use if you have VPN Client users attaching to your network.
LAN Subnets NOT to Use
192.168.0.0
192.168.1.0
192.168.5.0
192.168.10.0
192.168.50.0
192.168.100.0
10.0.0.0
10.0.10.0
172.16.0.0
172.31.0.0
genesearch
Thanks for responding, I will follow up with IPSecuritas support to check.
I know I can change my IP address range, but its probably 20 years already, and as you can imagine, its not easy. Otherwise I would have done so already.
As an alternative, Does setting up buily in OS X client work with FVS336G
Netgear support referred me to it, I cant get it to work, and neither can they (by remote controlling my computers and setting up themselves)
- aditFeb 16, 2016Mentor
I'm not an Apple guy so I'm not the best resource.
I think that tutorial was hit or miss back on the old forums. Searching the Archive in the new forum is useless.
That IPSecuritas issue goes back for maybe 10 years. I'm not aware of it ever getting resolved.
I think MC worked with Equinix VPN Tracker, but again just going off of memory.
