genesearch's avatar
genesearch
VPN use Mode Config Record fails
The FVS336G is the gateway and the LAN uses 192.168.1.x IP range.
I can create the IPSEC VPN, using VPN Policy as per the instruction manual, and it works great, and so easy to configure.
All my computers are Apple Mac OS X, and using  IPSecuritas as the VPN client, according to Netgear KB http://kb.netgear.com/app/answers/detail/a_id/24242
However, I have obvious problem when the remote client LAN also has same local IP address range of 192.168.1.x.   Its not a reasonable option for me to change my business LAN ip addresses.
After studying the manuals, KB etc, I see that the way to overcome this is to assign a different subnet to the incoming VPN clients and this is simply managed by changing the IPSEC VPN to use Mode Config Record.
This is pretty basic stuff,  On the Netgear just create a pool 192.168.169.1 to 254, and set the security the same as before, and enable Mode Config.
On the client, simply change the endpoint IP adress from 192.168.1.0/24 to 192.168.169.0/24 and go
The error message in the client is:
IKE [Netgear host IP] give up to get IPsec-SA due to time up to wait.
Error message in Router:
ERROR:  Failed to get IPsec SA configuration for: 192.168.169.1/24<->192.168.43.178/32 from vpnclient.private
I contacted Netgear support who then took remote control of my computes and configured IPSEC VPN straight from the manual - doiing nothing different than what I did, and get exactly the same problem.
If I flip the settings back to before,  on both client and host, the VPN works again.
It makes no difference whether XAUTH  is set to none,  or user login, the problem is the same.
Have tried on two different client MAC's on two different networks.
Netgear also attempted to create built in OS X vpn client using Cisco IPSEC configuration and result pretty much the same.
Any ideas?  I thought this should be simple.
  • The complete log from the router.
    Wed Feb 17 10:22:49 2016 (GMT +1000): [FVS336GV3] [IKE] INFO:  192.168.169.1 IP address has been released by remote peer.
    Wed Feb 17 10:22:49 2016 (GMT +1000): [FVS336GV3] [IKE] INFO:  ISAKMP-SA deleted for 59.100.xx.xxx[500]-1.132.9.76[500] with spi:414c513b9c0a8545:f63016e5a78baa48
    Wed Feb 17 10:22:48 2016 (GMT +1000): [FVS336GV3] [IKE] INFO:  Purged ISAKMP-SA with proto_id=ISAKMP and spi=414c513b9c0a8545:f63016e5a78baa48.
    Wed Feb 17 10:22:41 2016 (GMT +1000): [FVS336GV3] [IKE] ERROR:  Failed to get IPsec SA configuration for: 192.168.169.1/24<->192.168.43.178/32 from vpnclient.private
    Wed Feb 17 10:22:41 2016 (GMT +1000): [FVS336GV3] [IKE] INFO:  Responding to new phase 2 negotiation: 59.100.xx.xxx[0]<=>1.132.9.76[0]
    Wed Feb 17 10:22:36 2016 (GMT +1000): [FVS336GV3] [IKE] ERROR:  Failed to get IPsec SA configuration for: 192.168.169.1/24<->192.168.43.178/32 from vpnclient.private
    Wed Feb 17 10:22:36 2016 (GMT +1000): [FVS336GV3] [IKE] INFO:  Responding to new phase 2 negotiation: 59.100.xx.xxx[0]<=>1.132.9.76[0]
    Wed Feb 17 10:22:31 2016 (GMT +1000): [FVS336GV3] [IKE] ERROR:  Failed to get IPsec SA configuration for: 192.168.169.1/24<->192.168.43.178/32 from vpnclient.private
    Wed Feb 17 10:22:31 2016 (GMT +1000): [FVS336GV3] [IKE] INFO:  Responding to new phase 2 negotiation: 59.100.xx.xxx[0]<=>1.132.9.76[0]
    Wed Feb 17 10:22:30 2016 (GMT +1000): [FVS336GV3] [IKE] INFO:  Sending Informational Exchange: notify payload[INITIAL-CONTACT]
    Wed Feb 17 10:22:30 2016 (GMT +1000): [FVS336GV3] [IKE] INFO:  ISAKMP-SA established for 59.100.xx.xxx[500]-1.132.9.76[500] with spi:414c513b9c0a8545:f63016e5a78baa48
    Wed Feb 17 10:22:30 2016 (GMT +1000): [FVS336GV3] [IKE] INFO:  192.168.169.1 IP address is assigned to remote peer 1.132.9.76[500]
    Wed Feb 17 10:22:29 2016 (GMT +1000): [FVS336GV3] [IKE] INFO:  Received Vendor ID: DPD
    Wed Feb 17 10:22:29 2016 (GMT +1000): [FVS336GV3] [IKE] INFO:  Received unknown Vendor ID
    Wed Feb 17 10:22:29 2016 (GMT +1000): [FVS336GV3] [IKE] INFO:  Beginning Aggressive mode.
    Wed Feb 17 10:22:29 2016 (GMT +1000): [FVS336GV3] [IKE] INFO:  Received request for new phase 1 negotiation: 59.100.xx.xxx[500]<=>1.132.9.76[500]
    Wed Feb 17 10:22:29 2016 (GMT +1000): [FVS336GV3] [IKE] INFO:  Remote configuration for identifier "vpnclient.private" found
    • adit's avatar
      adit
      Mentor
      If I remember correctly Mode Config did not work with IPSecuritas.
      LAN1 192.168.1.0 to LAN2 192.168.1.0 will never work.
      If you are concerned about common LAN subnets having an issue with yours then you will need to change it.
      These are the one you should not use if you have VPN Client users attaching to your network.
      LAN Subnets NOT to Use
      192.168.0.0
      192.168.1.0
      192.168.5.0
      192.168.10.0
      192.168.50.0
      192.168.100.0
      10.0.0.0
      10.0.10.0
      172.16.0.0
      172.31.0.0
ProSupport for Business
