LAK1's avatar
LAK1
VPNG05L reset license
Hello, I´ve changed my laptop and install vpn ipsec client but when I try to activate the software I get error code 33 (the license is already activated in other device).
How can I activate the software once again?
Regards.
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    LAK1,
    Welcome to the community! :)
    The VPN license key needs to be reset so that you can use it to the new laptop.  Kindly send me the following below via private message:
    a. the VPN license key that needs to be reset
    b. e-mail address/es that was used when you have registered the VPN license key
    DaneA
    NETGEAR Community Team
    • LAK1's avatar
      LAK1
      Hello DaneA,
      the license I need reset is the following:
      email:d.laquidain@againsl.com
      license: 444xxx-xxxxxx-xxxxxx-xxxxxx
      Regards
      • DaneA's avatar
        DaneA
        LAK1,
        I just got a feedback from the higher tier of NETGEAR Support that your VPN license key has been reset. :)  You may now re-register it to your new laptop.
        If you were able to re-register it and have no further concerns, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution.
        DaneA
ProSupport for Business
