VPPBEEF
Dec 10, 2015Aspirant
WEB Apache Struts Wildcard Matching OGNL Code
Hi Community! I'm getting this reports daily (30 more or less), and I've been reading about it, and I don't know what exacatly what can I do to my firewalls to get rid of this messages, or if bec...
- Dec 15, 2015
Thank you very much and for your team too. You guys are awesome!
JohnRo
Dec 10, 2015NETGEAR Employee Retired
VPPBEEF,
Welcome to the community!
It appears that these are just normal logs detected by the IPS. It looks like it might be coming from phishing sites but I'll have to check on that and get back to you. What is the firmware version that your are running on the UTM10?
Thanks,
VPPBEEF
Dec 11, 2015Aspirant
Hi John,
Thanks for your help. The firmware version is the one under: Administration>System Update>Firmware?
If it's that one says:
Firmware reboot:
Active - Version 3.6.2-1
I hope this help... Otherwise let me know. Thanks!
