andy_vdg's avatar
Aug 14, 2015
Apache configuration problem for several apps
Hoping someone can help.
I've got following apps installed:
Plex, OwnCloud, PHP, PHPMyAdmin, VirtualHere USB Hub, DropboxManager.
Frontview, Plex and OwnCloud work fine however I get following errors when I try and open the other apps:
PHP
Safari can't open the page "192.168.1.9:7081" because Safari can't connect to the server "192.168.1.9"
PHPMyAdmin
Safari can't open the page "192.168.1.9:7082" because Safari can't connect to the server "192.168.1.9"
DropboxManager
Not Found
The requested URL /apps/dropbox/ was not found on this server.
Apache/2.2.29 (Debian) Server at 192.168.1.9 Port 443
 Any help would be appreciated.
  • Thanks for looking into it... not sure if you did anything specific but everything except Dropboxmanager started working again.
    I did get this error when trying to restart apache2:
    service apache2 restart
    [....] Restarting apache2 (via systemctl): apache2.serviceError: No space left on device
    ^[[AJob failed. See system journal and 'systemctl status' for details.
     failed!
    So I did a quick google search and added "fs.inotify.max_user_watches = 262144" to sysctl.conf
    nano /etc/sysctl.conf
    then ran
    sysctl -p
    and restarted apache2 after which everything ran again
    service apache2 start
    [ ok ] Starting apache2 (via systemctl): apache2.service.
      • mdgm-ntgr's avatar
        mdgm-ntgr
        NETGEAR Employee Retired
        Can you send me your logs (see the Sending Logs link in my sig)?
ProSupport for Business
