OWEN22's avatar
OWEN22
What is the difference between FVS336G and FVS336Gv3
Hi Hopchen / DaneA,
Good day Sir's
I just want to ask what is the diference of   FVS336G and  FVS336Gv3 is it only a firmware version?
regards,
Owen->Ruel
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi OWEN22,
    I moved your post to the appropriate discussion board.
    Here below are the differences between FVS336G (FVS336Gv1) and FVS336Gv3:
    Be reminded that both FVS336Gv1 and FVS336Gv3 are already End-of-Life (EOL).  Kindly check the announcement here.
    DaneA
    NETGEAR Community Team
    • OWEN22's avatar
      OWEN22
      Hi DaneA,
      Thank you for the info. the product are in EOF, Any other Netgear product router that Vlan Aware that you can recomened DaneA.
      Best regards,
      Owen
    • DaneA's avatar
      DaneA
      OWEN22,
      As per the link I have provided from my previous response, the whole NETGEAR VPN Firewall product line that supports VLAN was recently declared EOL (End-of-Life) last September 1, 2017.  I'm afraid that currently, there is no NETGEAR firewall / router that supports VLAN which is not EOL that I can suggest.
      DaneA
      • OWEN22's avatar
        OWEN22
        Hi DaneA,
        Maybe I will stick with the FVS336Gv3, but  I cant find any trusted reseller here in japan can you help me find a good trusted store.
        Best Regards,
        Ruel
ProSupport for Business
