aeaeae5's avatar
aeaeae5
Tutor
Apr 13, 2024
24v or 48v PoE for WAX615?
Do I need 24v or 48v PoE for the WAX615? is 24watts enough for max power or do I need 30w?
  • schumaku's avatar
    schumaku
    Afraid, looks like you are on the wrong boat, sorry saying.
    Netgear does (mostly) use IEEE compliant 802.3af, 803.3at, and 802.2bt PoE, not the dirt cheap passive, non-IEEE compliant passive PoE. For the WAX615 you need to calculate at least 21.2 Watts, this translates to a switch (or for the sake a power injector) with complete 802.3at support - otherwise (in case of a 802.3af) the radios will operate on lower bandwidth like 1x1 mode only.
    When you have an eye on the Netgear PoE AP Datasheets like WBE7xx, WAX6xx (for example the WAX615 Data Sheet), or WAC5xx, you wont find any voltage and amps data for this very same reason - only IEEE PoE versions, and PoE power consumption.
    A standards compliant Power Source Equipment (PSE) will not supply any power, except of the basic Ethernet links, to the Powered Device (PD). The difference between the maximum power at the PSE and the powered device is cause by the normal cable loss.
    Of course, the voltage is standardized, look for example https://en.wikipedia.org/wiki/Power_over_Ethernet
    Said that: No IEEE compliant PD will do the handshake required to get power from a passive non-standard "PoE-like" switch or injector.
    This is about what you have to know about the one-and-only real PoE,
    -Kurt.
    • schumaku's avatar
      schumaku
      While talking of PoE/PoE+/PoE++ power injectors: What hits my eyes is that very few PoE injectors are supporting Ethernet link speeds >> 1 GbE. So yes, keep in mind the WAX615 does have a 2.5 GbE LAN connection, which of course can be operated on just 1 GbE, too.
  • Not sure If it helps or not, I plugged mine into a GS110TP v3 and with default settings of:
    Current Power Usage: 4.8W
    PoE Standard: 802.3at
    Detection Type: IEEE802
    Power Limit Type: Detected Class
    Power Limit (watts): 30
    Been working fine ever since (a few months now)
  • ErwinL's avatar
    ErwinL
    NETGEAR Moderator
    Hello aeaeae5
    And welcome to the NETGEAR Community! 🙂
    According to the data sheet it supports IEEE 802.3af or 802.3at power over Ethernet (PoE). So the maximum power it supports is up to 25.5 watts.
    Have a lovely day,
    Erwin
    Netgear Team
ProSupport for Business
