Soogs
Mar 29, 2024Guide
WAX615 - Mesh / Roaming
Hi all, first post here 🙂
I have just purchased and setup 2x WAX615 WAPs
So far they are working fine but I am a bit confused as to how I am meant to enable roaming.
I have setup and enabled insight account and set both WAPs to insight management mode.
In Mesh Topology both units are set to Auto - do I need one as Root and the other as Extender?
I do not want a wireless Mesh as the backbone is hardwired.
Do I need to just trust that it is working in Auto?
Thanks
Welcome to the Netgear Community!
Roaming can work implicitly by configuring the same SSID and same security key if using WPA2-PSK (WPA2-Personal).
To explicitly enable Fast Roaming (802.11r), you need to use Insight, head to the Edit Wireless Settings, and select for each of the SSID Fast Roaming (802.11r):
You could leave it on Auto. However, I suggest to take control and disable Mesh completely as a security and operational measure. Especially if you have no intentions to operate one or more WAX6xx as complete wire-free Mesh satellites.
Hope this explains.
-Kurt.
Hope this explains.
-Kurt.
- SoogsGuide
Amazing thank you.
I have also enabled load balancing following advice from another user on reddit.
