Soogs
Mar 29, 2024Guide
WAX615 - Mesh / Roaming
Hi all, first post here 🙂 I have just purchased and setup 2x WAX615 WAPs So far they are working fine but I am a bit confused as to how I am meant to enable roaming. I have setup and enabled ins...
- Mar 29, 2024
Welcome to the Netgear Community!
Roaming can work implicitly by configuring the same SSID and same security key if using WPA2-PSK (WPA2-Personal).
To explicitly enable Fast Roaming (802.11r), you need to use Insight, head to the Edit Wireless Settings, and select for each of the SSID Fast Roaming (802.11r):
Soogs wrote:
I have setup and enabled insight account and set both WAPs to insight management mode.
In Mesh Topology both units are set to Auto - do I need one as Root and the other as Extender?
I do not want a wireless Mesh as the backbone is hardwired.
Do I need to just trust that it is working in Auto?
You could leave it on Auto. However, I suggest to take control and disable Mesh completely as a security and operational measure. Especially if you have no intentions to operate one or more WAX6xx as complete wire-free Mesh satellites.
Hope this explains.
-Kurt.
schumaku
Mar 29, 2024Guru - Experienced User
Hope this explains.
-Kurt.
- SoogsMar 29, 2024Guide
Amazing thank you.
I have also enabled load balancing following advice from another user on reddit.
- schumakuMar 29, 2024Guru - Experienced User
Permitting both APs are covering about the same or similar wireless arena, and on dedicated channels each, yes.
not so much an arena, using these at home (3 floor end of terrace house).
placed both on the middle floor, one in the front bedroom/office and the other in the back bedroom.
to be fair one of these would have probably be fine if it wasnt for the fact that I rely on wifi calling as my network is trash here and the garden is pretty huge so need as much coverage as possible.
channels are set to auto and when I last checked they were on different channels
