Caramba's avatar
Caramba
access to WAC124 with double layer security
After entering login + password, Netgear sends me a validation number to my phone, but after entering the code I get an error message 'connection has been reinitialized'.
No way to get access to the wifi access point
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Caramba,
    Welcome to our community! :)
    It seems that you are having issues with your login to the WAC124. Have you tried resetting it to factory default? May I know also if you are using the Insight app?
    John
    NETGEAR Community Team
  • 1 - I lost the habitily to log in to the access point, but it still worked correctly
    2- I'm not using an app to control it, but a work station (under linux, which controls the local network)
    3 - The device is at this time in storage, I'll need to reinstal it when I get into a new home
    4 - Thanks for your help
ProSupport for Business
