Tom_G
Apr 22, 2025Tutor
Can't login to WAC124 any more
Hi,
Today, I realized I couldn't log into the WAC124 any more, even though I've been able to do that for the past 3 years. I'm still able to use it as WiFi Internet access point, though.
The router is connected to a modem through a switch and Ethernet cables, since it's in another room. I'm using it mostly to get WiFi from other parts of the house the modem can't reach.
When I try to login, the login/password are correct and accepted, I get the "Checking the Internet connection; please wait …", then it goes back to the login page.
What I tried:
1) I powered it off/on, no improvement.
2) I reset it, no improvement.
3) Direct connection:
I tried to connect a laptop directly to one of the LAN ports after disconnecting the router from the Internet (the yellow port), and opened the browser on www.routerlogin.net, but it can't connect (which is logical). I also tried to connect with the browser to 192.168.0.100, but it can't connect either. A ping to that address doesn't work, either. All that is normal since it's not on the network any more, and the modem is the device managing the network with DHCP.
4) I also tried to disconnect it from the Internet and to connect to it with WiFi, but that doesn't work.
Since it's been bought 3 years ago, there is no support. I'm almost wondering if the fact I can't login with the normal Internet access has something to do with it.
Is there a way to connect to that router with a laptop (for instance) and try to see what's wrong?
Something else I observed: every few months, it seems to freeze, and I have to restart it. I suspect it to wreak havoc on the local network every now and then, too (I have to reboot it, and restart the two other switches on the network to restore things).
PC (static IP) 192.168.0.123 255.255.255.0 gateway 192.168.0.1 <-> WAC124 (DHCP) 192.168.0.100
-or-
Alternate approach block the WAC124 LAN IP on your router from the Internet access. This won't impact the Wi-Fi / WLAN access to the LAN
Essentially what I explained above already - operate the WAC124 offline!
the WAC124 is an access point. do you have it connected to a router?
If so, what one?
did you log into the route to see what address it assigned to the WAC?
Use that to try to access it .
Almost everything here is "logical" dear Tom_G - as this is about networking and computers, which commonly exactly behave as designed and implemented.
The routerlogin.net DNS query can be captured on the AP when the request does pass the device - it will return the device LAN IP.
The default 192.168.0.100 IP address is only in place in case there is no DHCP server returning a valid IP for your LAN IP subnet.
When operating the WAC124 offline - so no connection to your LAN with DHCP server - the DHCP client (permitting there is no static LAN IP defined) is likely fall-back to the default LAN IP 192.168.0.100 (/24, 255.255.255.0 subnet mask). This does require an Ethernet LAN config in that subnet, so 192.168.0.x (.1 ... .254) on your computer Ethernet adapter. At that point is no Internet connection, so the outdated Netgear Single Sign-on feature won't be active, but was defines obsolete and removed almost three years ago. Said this, with a correct network adapter config, and only a direct connection PC <-> WAC124, a login is certainly possible, without "Checking the Internet connection ...". At that point you can install https://kb.netgear.com/000065060/WAC124-Firmware-Version-1-0-4-9
-Kurt.
- Tom_GTutor
schumaku wrote:The routerlogin.net DNS query can be captured on the AP when the request does pass the device - it will return the device LAN IP.
I know its assigned IP, but it's apparently not possible to log into the WAC124 without using Netgear's remote server while it's connected to the Internet, so I have to disconnect it first before I can use the local admin login.
I'm using a modem/router, which is imposed by my provider, so the only way to remove Internet is to unplug the cable between the modem and the DSL filter, which would disconnect the Internet for everyone else. The other solution would be to isolate the WAC124 from Internet with the modem/router, but I doubt it can do that.
Ah, so that explains it. Netgear's basically sawn off the branch on which its product was sitting, not very smart (unless it's on purpose).
Yes, that's exactly what I'm asking. That's what I've been trying to do, but without any success (and I understand why it didn't work, since I explained the current DHCP configuration).
What are the owners of that device supposed to do after they shut down their server?
I suppose my only option is to temporarily disable Internet for everyone, or start messing with a local router and just a laptop and this WAC124, which I really would like to avoid. They could just have added a checkbox "local connection", but no, it would have been too user-friendly. An overall lazy design with a very limited guarantee.
Thanks for the link to the new firmware! I'll make sure to install that if I can get past the login.
-or-
