e_John
Aug 26, 2016Aspirant
add newer AC or N WAP to existing wireless network ?
I have an existing network, with (3) Netgear WAPs (N-class), WN802T. I have some spotty coverage, and was thinking about adding two more, but perhaps a different Netgear model. I want to use the sa...
- Aug 29, 2016
Hi e_John,
Are your WN80T access points a version1 or version2?
Let me share the article below. I would assume that most of the questions you might think of between the 802.11ac and 802.11n standards are found in it. It would also introduce you to the WAC720 and WAC730 access points.
ProSAFE WAC720 and WAC730 and everything 802.11ac Frequently Asked Questions
Let us know if you have further questions.
DaneA
NETGEAR Community Team
DaneA
Sep 01, 2016NETGEAR Employee Retired
Hi e_John,
We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance. If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
