roman930's avatar
roman930
Follower
May 22, 2023
Admin login for WAX620 access point?
I bought a WAP WAX620 used. I reset it before putting it to use. I could use the Insight app to manage it during the first 30 days. After the trial is over, I want to use the web interface. When I do, I can't login with the correct credentials. I tried admin and password, admin and 1234. None is working.
  • FURRYe38's avatar
    Credentials would be what ever you input using the Insight app to set up the AP after you did the factory reset and setup from scratch.
  • schumaku's avatar
    schumaku
    Setting the local admin password (with Insight) is done in the Location Configuration under the Device Admin Password nicely location wide. Convinced this information is queried during establishing of the first location.
    Head to the App ->Location Configuration ...  and you can figure out what was set back then.
    Amazing, had replied to the exact same post some two days ago already ->  Admin login for WAX620 access point?
ProSupport for Business
