Lambik2000
Nov 12, 2020Follower
Advise needed in WAC540 and WAC564 network
Dear community, I hope you can help me a little. I will describe my situation but also made a drawing to make that visible. I want to have a good coverage in my whole house and therefore I decid...
schumaku
Nov 13, 2020Guru - Experienced User
Consider adding two Ethernet cables from the PoE switch from the living room to the bedroom 2 and 3. Alternate move the PoE switch to another central location suited better for cabling.
