vpoppy
Mar 18, 2021Aspirant
amber light blinking on power
Hi, I'm trying to configure and reset a few APs that used to be part of another network that was controlled by NetGear Wireless Management switch. However the APs continue to flash amber light, r...
vpoppy
Mar 28, 2021Aspirant
Hi John,
Thanks for the suggestion, I have tried your suggestion, but i couldn't ping or access via browser the 192.168.0.160 address.
The model of the controller that it had been connected to would be the Pro Safe WC7500 controller.
Thank you :)
JohnC_V
Apr 01, 2021NETGEAR Employee Retired
Please try to do a factory reset by pressing the reset button for 30 seconds, then turn it off. Continue to hold the reset button for another 30 seconds and turn it on while still holding the reset button for another 30 seconds then release.
Please let me know if that would work.
John
NETGEAR Community Team
- vpoppyApr 13, 2021Aspirant
Hi John,
As mentioned in my original post (30/30/30 reset method) I have already tried that and unfortunately it has stayed amber.
I didn't think factory reset to a standalone access point will be this difficult.
Regards
