vpoppy
Mar 18, 2021Aspirant
amber light blinking on power
Hi, I'm trying to configure and reset a few APs that used to be part of another network that was controlled by NetGear Wireless Management switch. However the APs continue to flash amber light, r...
JohnC_V
Apr 16, 2021NETGEAR Employee Retired
My apologies for that. It would be best you will open a ticket on NETGEAR support and please let them know the status of your Access point so that we can identify if this is already a hardware fault. If the device is still under warranty, an online replacement will be provided.
John
NETGEAR Community Team
