jokicevic
Oct 24, 2023Aspirant
AP WAX630E PoE++ injector or switch
Hi all, can anyone advise me on whitch PoE switch or injector would be suitable for WAX630E? I just get YuanLey Gigabit 60W, PoE++ Injector but it seams that it dose not work. I notece that on ...
jokicevic
Oct 25, 2023Aspirant
As we are not shure what product can be compatible with yours can you please indicate the vendor/product that can be sure that is compatible with your device?
Switch and injector.
Can we use POE+ 802.3AT switch or injector as well or not?
Thanks.
schumaku
Oct 25, 2023Guru - Experienced User
Netgear has several switch models properly supporting the required power IEEE 802.3bt, and at least 2.5 GbE links, like the unmanaged MS108UP (not allowing multiple VLANs and independent SSID), the Plus managed MS108EUP, and on the higher end of the product lines the fully managed M4350 Managed Switches 1G to 25G for AV over IP and IT
These are not my devices ... I'm just yet another Netgear customer.
802.3at does only support Type 2, so max 30W at the PSE resp. 25.5W at the PD what is not sufficient for the WAX630 or WAX630E (without reducing capabilities or power). Keep in mind that most 802.3at devices are supporting 1 GbE only.
