Kopaka
Feb 01, 2023Follower
WAX630 POE++ Injector
Hello Everyone,
I have a WAX630 with the most recent firmware and I am attempting to find a compatible POE++ injector. I have tried an Ubiquiti POE-50-60W (https://store.ui.com/collections/unifi-accessories/products/unifi-poe-adapters?variant=40285582426201) which says it supports POE++ and 60 watts of power but the WAX630 is saying it is in AF power source mode and not AT mode. Does anyone have any experience with this issue?
Reads like a potential interop issue, to be investigated by Netgear.
- q8-bbcodeAspirantI have the issue, I tried 2 POE injector both POE+ and Unifi POE-50-60W POE++,
both doesn't work af mode.- schumakuGuru - Experienced User
There is a big mess in the market, especially caused by makers like Ubiquity when it comes to standard compliant PoE+/PoE++ power injectors.
Provide exact model numbers please. What I see on the other vendor spec sheet as POE-50-60W, POE-50-60W-WH is very likely some kind of non-standard compliant passive power-over-ethernet injector. My distributor does misleadingly state for the "PoE Injector POE-50-60W 50 Volt GE 60 Watt" it is a PoE Standard "50V passive PoE". "PoE Standard" - i would like to cry out loud. This is proprietary junk!
