RottenMutt
Oct 04, 2024Aspirant
what PoE injectors work with WAX630
i tried a Procet EN60GB-10 PoE++ injector and the WAX630 still runs at reduced power. I'm running my router in access point mode, don't know if that matters. any injectors work with this router? you would think the router would detect power on all four twisted pairs and realize it has 60 watts, PoE++ and more has power on all four twisted pairs. i believe the Procet injector is passive, and radio are not enabled. with the GS324TP it runs at reduced through put...
- RottenMuttAspirant
I tried tp-link TL-SG105PP-M2(UN) VER 1.6, but it failed just like the POE adapter.
suppose to be PoE++ and 2.5G, the 2.5G worked.
edit: tried with 3 foot store bought cable and get same result. comes up initially full power, shuts down radios; attempts at PoE+, shuts down radios; comes back with no radios...
- PramendraNETGEAR Expert
Hi RottenMutt
Thanks for reaching out. We are checking internally on this and will come back to you ASAP.
Thanks!
Pramendra
NETGEAR SMB Wireless
purchased a MS108EUP POE++ switch and it works with the WAX630...
- BrianLNETGEAR Moderator
Hi RottenMutt.
The Procet EN60GB-10 PoE++ injector can work with the GS324TP switch to power the WAX630 access point using 802.3at (PoE+). Using the Procet EN60GB-10 injector, you can ensure that the WAX630 receives sufficient power even if the GS324TP switch only provides PoE+ power. This setup will allow the WAX630 to function properly, though for peak performance, PoE++ is ideal.
Kind regards,
BrianL
