RottenMutt
Oct 04, 2024Aspirant
what PoE injectors work with WAX630
i tried a Procet EN60GB-10 PoE++ injector and the WAX630 still runs at reduced power. I'm running my router in access point mode, don't know if that matters. any injectors work with this router? y...
RottenMutt
Oct 05, 2024Aspirant
I tried tp-link TL-SG105PP-M2(UN) VER 1.6, but it failed just like the POE adapter.
suppose to be PoE++ and 2.5G, the 2.5G worked.
edit: tried with 3 foot store bought cable and get same result. comes up initially full power, shuts down radios; attempts at PoE+, shuts down radios; comes back with no radios...
- PramendraOct 07, 2024NETGEAR Expert
Hi RottenMutt
Thanks for reaching out. We are checking internally on this and will come back to you ASAP.
Thanks!
Pramendra
NETGEAR SMB Wireless
