RottenMutt
Oct 04, 2024Aspirant
what PoE injectors work with WAX630
i tried a Procet EN60GB-10 PoE++ injector and the WAX630 still runs at reduced power. I'm running my router in access point mode, don't know if that matters. any injectors work with this router? y...
BrianL
Oct 10, 2024NETGEAR Moderator
Hi RottenMutt.
The Procet EN60GB-10 PoE++ injector can work with the GS324TP switch to power the WAX630 access point using 802.3at (PoE+). Using the Procet EN60GB-10 injector, you can ensure that the WAX630 receives sufficient power even if the GS324TP switch only provides PoE+ power. This setup will allow the WAX630 to function properly, though for peak performance, PoE++ is ideal.
Kind regards,
BrianL
