Kopaka
Feb 01, 2023Follower
WAX630 POE++ Injector
Hello Everyone, I have a WAX630 with the most recent firmware and I am attempting to find a compatible POE++ injector. I have tried an Ubiquiti POE-50-60W (https://store.ui.com/collections/unifi-...
q8-bbcode
Mar 17, 2023Aspirant
I have the issue, I tried 2 POE injector both POE+ and Unifi POE-50-60W POE++,
both doesn't work af mode.
schumaku
Mar 18, 2023Guru - Experienced User
There is a big mess in the market, especially caused by makers like Ubiquity when it comes to standard compliant PoE+/PoE++ power injectors.
Provide exact model numbers please. What I see on the other vendor spec sheet as POE-50-60W, POE-50-60W-WH is very likely some kind of non-standard compliant passive power-over-ethernet injector. My distributor does misleadingly state for the "PoE Injector POE-50-60W 50 Volt GE 60 Watt" it is a PoE Standard "50V passive PoE". "PoE Standard" - i would like to cry out loud. This is proprietary junk!
