blacknell
Feb 27, 2025Guide
Audi Q4 can't see or connect to WAC540
I have a WAC540 running latest firmware 9.9.5.1 I have a lot of devices connecting to it just fine. Very reliable. My new Audi Q4 eTron will not see the broadcast SSID when it scans for hotsp...
blacknell
Feb 28, 2025Guide
OK. I get your point. I will try and find out firmware in the car is latest
But the same argument could be said of Netgear. The car can see many many many SSID's as I drive around - just not this Netgear one.
Feb 28, 2025Guru - Experienced User
But the same argument could be said of Netgear. The car can see many many many SSID's as I drive around - just not this Netgear one.-----Whats netgear going to check? its broadcasting as your other devices can see it. If it was having an issue, NOTHING could see it. But when its just one device that can't see a broadcasting ssid, it indicates its the device (car) with the issue. Again, we've seen this issue before when devices transitioned to newer wireless standards and needed an update. Its also why its recommended to check the Audi forums to see if anyone else has seen this issue. A quick google shows a ton of posts of Audi not seeing wifi/ssids.
