XtheEdgeX
Nov 29, 2023Tutor
AX1800 WAX202 Slow LAN ports
I have the WAX202 set up in AP mode. I have CAT 6 ran to a few locations in my home with the AP at my living room TV. Any wireless connections to it are good. Anything connected to a LAN port is slow...
Nov 30, 2023Guru - Experienced User
You have the firestick hardwired in using a usb/ethernet adapter? (as the firesticks don't have ethernet natively)
- schumakuNov 30, 2023Guru - Experienced User
Correct - most if not all Firestick have some USB based hack based on an USB OTG port, by far not able t reach the full USB 2.0 performance. Be happy if you get some 300...350 Mbps - ways off from a full GbE connection.
- XtheEdgeXNov 30, 2023Tutor
Yes, I failed to say that it's connected through a 1Gbps adapter. I may have found my answer, though. I had researched before buying the Fire Stick and found that it would download up to 1G with the adapter. I don't know where I found that info. Today I found an amazon specs page that shows the Fire Stick is 10/100. When the FS was connected via WiFi, it would buffer sometimes even though the speed test in the settings menu showed about 200Mbps. I tried the WiFi adapter and the buffering stopped and it's speed test shows a little over 300Mbps. So I'm not sure why the speed tests show that high when the FS is limited to 10/100. I had assumed it was a LAN port issue. I will find something else to plug into the access point and test it.
As I said: There are some USB OTG adapters which establish a GbE link, however the performance will be ways off from a full GbE. Lipstick on a pig, originally designed for Fast Ethernet only.
- plemansNov 30, 2023Guru - Experienced User
It really shouldn't cause buffering, though. A 100mbps link will be fine with streaming 4k. If you look, most 4k tv's only have 10/100mbps ports on them anyway because the higher bandwidth isn't needed, and its cheaper.
One of my 4k tv's only supports a 100mbps link and it streams fine wired or on wireless. (i prefer the wired option but have used both)
might be worth checking into what adapter you have. maybe it's got issues causing the buffering.
