netgruser's avatar
netgruser
Follower
Oct 09, 2022
WAX202 as a secondary router
I would like to use the WAX202 router as a secondary router on a separate subnet on a home network.  My main subnet is 192.168.3.0 and the WAX202 will be 192.168.4.0.  I would like devices on both to be able to communicate.  The devices on the WAX202 network can ping/connect to devices on the 192.168.3.0 network.  However devices on the main network cannot ping/connect to devices on the WAX202 network.  The WAX202 has a static wan ip address of 192.168.3.2.  I have a static route set up on the main router that traffic destined to 192.168.4.0 should route to 192.168.3.2.  With other routers and firmwares (openwrt), this was possible.  I know I had the disable the firewall and allow all forwarding to/from the WAN<->LAN.  Is this possible on the WAX202?  Thanks.
  • Unless I'm missing something essential, this makes devices make up a NAT router only, so configuring a classic IPv4 static routing environment adding a route e.g. from the 192.168.3.0/24 to the 192.168.4.0 /24 subnet is probably not possible. The reason is that the WAX does NAT-block any connection attempts from the "WAN" subnet to the LAN subnet is not possible. You won't be able to talk direct to an address in the WAX202 LAN subnet.
1 Reply
  • schumaku's avatar
    schumaku
ProSupport for Business
