netgruser's avatar
netgruser
Follower
Oct 09, 2022
WAX202 as a secondary router
I would like to use the WAX202 router as a secondary router on a separate subnet on a home network.  My main subnet is 192.168.3.0 and the WAX202 will be 192.168.4.0.  I would like devices on both to...
  • schumaku's avatar
    Oct 09, 2022
    Unless I'm missing something essential, this makes devices make up a NAT router only, so configuring a classic IPv4 static routing environment adding a route e.g. from the 192.168.3.0/24 to the 192.168.4.0 /24 subnet is probably not possible. The reason is that the WAX does NAT-block any connection attempts from the "WAN" subnet to the LAN subnet is not possible. You won't be able to talk direct to an address in the WAX202 LAN subnet.
ProSupport for Business
