XtheEdgeX
Nov 29, 2023Tutor
AX1800 WAX202 Slow LAN ports
I have the WAX202 set up in AP mode. I have CAT 6 ran to a few locations in my home with the AP at my living room TV. Any wireless connections to it are good. Anything connected to a LAN port is slow...
Nov 30, 2023Guru - Experienced User
You have the firestick hardwired in using a usb/ethernet adapter? (as the firesticks don't have ethernet natively)
schumaku
Correct - most if not all Firestick have some USB based hack based on an USB OTG port, by far not able t reach the full USB 2.0 performance. Be happy if you get some 300...350 Mbps - ways off from a full GbE connection.
