BretD
Apr 29, 2021Administrator
AX3600 WiFi 6 Dual Band Multi-Gig Access Point WAX620 with Optional Insight Cloud Management
Introducing the NETGEAR WiFi 6 AX3600 Dual Band Multi-Gig Access Point. Featuring the latest WiFi 6 technology and ideal for high-density environments with a large number of devices, small and medium-sized businesses can now enjoy enterprise-level security without the enterprise budget. This new high-performance WiFi 6 Access Point joins our existing line of WiFi 6 access points.
The WAX620 and offer customers and employees the best WiFi with higher speeds, less congestion, higher device density and higher battery life for WiFi 6 smartphones. Achieve Multi-Gigabit speeds by utilizing the 2.5 Gbps Ethernet port with PoE Power for higher speed and easy wiring. Experience uncompromised security features, like secure sub-networks with 8 SSID’s, separate VLANs, and WPA3 authentication. Easily set up and manage your WAX620 access points by using NETGEAR Insight: cloud-based, fully centralized, real-time remote monitoring, with no need for extra management hardware.
Read the WAX620 Press Release.
Visit the AX3600 Access Point WAX620 Store page.
In our recent blog learn how the WAX620 and other Insight Access Points are helping IT managers deploy school Wifi for hybrid models as classes reopen.
