coyote3's avatar
coyote3
Guide
Sep 15, 2019
Multi-Gig port to PC?
Can I connect via the RAX120's Multi-Gig port (5G/2.G/1G) to a PC, with say a 5G ethernet port, and get 5G?
    • coyote3's avatar
      coyote3
      Guide
      Thank you very much, avtella!
      The manual and product page didn't make that clear enough.
      • avtella's avatar
        avtella
        Prodigy
        It’s only a WAN (Internet side) port if you specifically select the 5gb port as WAN in internet settings, otherwise it acts as a LAN port. I have it connected to a 10Gbps switch (at 5Gbps link rate) which is connected to my NAS.
